- 1 Jan 2012
- Scottish Borders - UK
Curious as to what's regarded as the best "silent" case out there? Without going stupidly expensive.
"modu-vent system" = little bits foam stuck over them right?![]()
no, it's not, it's actually plastic mounted over the fan mounts with sound dampening foam on it too
You just can't hack being wrong can you?
The solo II is just a tad bit better.there is no silent case that can match the r3! even ttl said the r3 is better in the reviews of the h2 and silencio 550
silentpc said:The cumulative results of all these changes is excellent performance. Thermally, the Solo II outperforms the Cooler Master Silencio 550 and NZXT H2 in convincing fashion. It goes go toe-to-toe with the Fractal Define R3, perhaps exceeding it by virtue of its hard drive suspension system
