One thing that really puzzles me is that ATI on paper has the much better card for that price range, what are they doing wrong to make it slow down?
4890 Vs 275
1024mb Vs 896mb
GDDR5 vs GDDR3
GPU Clock: 850mhz Vs 633Mhz
Mem Clock: 3900mhz vs 2268mhz
processing cores: 800 vs 240
Really there should only be one winner but why in testing does the 275 come out on top most of the time? Crackers.![]()
GDDR5 vs GDDR3 ~ The 275 has 448bit bus width, whereas the 4890 only has 256bit.
Why do I keep seeing people at multiple forums using this for a reason to purchase a 260/275 over a 4870/4890?![]()
noobs tbh
Neither the GTX275 and or HD4890 are worth buying, save some money and get a GTX260 instead, you won't notice any difference, especially if your overclocking they will all end up around the same performance anyway.
What if you overclock a GTX275 won't that be much faster then a overclocked 260?
