s0ck said:Excuse the late reply
I'm hoping to use MS Exchange 'direct push' on it, so it will need to have Windows Mobile 5, I believe. It looks like the network may have to be T-mobile, which I guess will limit which handsets I can use?
Energize said:All pda phones will work on any network so it won't limit it in that respect.
Tomsk said:Branded PDA phones will generally work better with their associated network because the network provider will have tested it. They're also likely to have fewer bugs.
Energize said:Almost all of the pda phones are all made by the same company so the hardware and software are exactly the same.
