Best stuff for getting oil off chain ?
25 Nov 2005
Trying to give my bike a clean but everytime I clean near the chain I'm somehow managing to smudge the black oil onto the white paint and it's ******* me off as my bike is looking less clean than before I began.
Preferably stuff that's safe to use on the frame to get rid of the new smudges too, I'm thinking to take the whole chain set off so I can clean the frame properly, clean the chain set then put it all back together fresh and clean or is this a bad idea ?
Depends if you want good solvent type degreaser or a friendly citrus cleaner. Both work well. I use the Park Tools citrus cleaner and chain cleaning tool and it works really well
I'll have a look for a citrus cleaner then as I'd rather avoid the solvents with them not being bio friendly seen people suggest this stuff https://www.screwfix.com/p/no-nonsense-heavy-duty-degreaser-5ltr/88668 doesn't say whether it's citrus based or solvent though
You can see what’s in it in the COSHH sheet under specification. Whatever is in it is nasty, warning that it is seriously damaging to eyes, don’t let it reach water course or the sewage system :eek:
None of them are toxic though, I just googled the ingredients they are found in household detergents, laundry detergent, shampoo, beauty cosmetics and strangely.... chicken nuggets, cat food and toothpaste so I'm assuming it's safe to wash down the drain, just not splash in my eyes or drink
I've posted on the swarfega before https://forums.overclockers.co.uk/posts/30517939, it has salt,
as bloodied said, it's strong, I use it w/gloves diluted with boiling/kettle water for the chain and other removable components, which I can rinse thoroughly,
negligible foam if you want to use it on 'whole' bike.
(would also like to try a cheap ultrasonic bath too and see how that might help)
Got an empty coffee jar I was going to use for holding it so I'll mix with some water, also bought a box latex gloves and a paintbrush to get it on as I don't fancy spraying/splashing it everywhere if it's only the chain set I want degreasing and the little part of frame/bottle holder I've managed to coat in oily residue from trying to clean without degreaser :confused:
Never knew cleaning a bike would require such research though, always in the past a rinse with soapy water seemed good enough but that was only for £100 cheapo bikes so didn't really care as much I do my more expensive one just got to hope the rain holds off long enough for me to get the chain sorted
Well the Swarfega stuff worked a charm, started off with diluted but ended up just using it neat as the gears needed it, now got a completely clean chain and gears, only thing I was missing was a crank removal tool so I could get at the part of the frame covered by the crank which is the most oily/dirty so I'll have to come back to that Monday when my tools arrive.
It's certainly been a great learning experience
gears - you mean rear block / chainwheels - what utensil did you apply it with ?
It's water based and biodegradable...
well - I would not put it on my breakfast cereal
General notes: Do not allow product to reach ground water, water course or sewage system. Danger to drinking water if even small quantities leak into the ground. In accordance with the requirements of the RVO in the Act on Detergents and Cleansing Agents, tensides are biodegradable up to at least 90 %
Recommendation Small amounts may be diluted with plenty of water and washed away. Dispose of bigger amounts in accordance with Local Authority requirements. Smaller quantities can be disposed of with household waste.
When the chain gets to the point its covered in black muck it needs cleaning and re lubing, or even just a wipe down to get the black muck off, as dirty lube on the outside of the chain serves no purpose.
So clean your chain up before washing the bike, just make it part of the washing schedule, if you keep on top of it it'll never get too bad, and will be quicker.
I have only used the degreaser on individual disassembled components, and, so far, have not used it on still mounted chain rings/sprockets for fear of getting some in the vicinity of the bottom bracket/frewheel bearing or even chain ring bolts, where alkinlinity might cause sticking/corrosion.
Currently use old bottle of shampoo and a muc-off sponge(1st dedicated sponge I ever bought) on 'whole' bike.
If you keep the chain reasonably clean and lubed, you'll never really need to clean the cassette /chain rings aside from a simple wipe down if it's gotten muddy.
