Best thermal compound?
18 May 2011
As the title says lads
since its been quite toasty recently my temps have gone up
whats the best thermal comnpound i can use on my cpu?
ill spend about 10 quid
thank you in advance :)
edit
i have the amd x4 955 be c3 and its hitting about 75 degrees overclocked at 3.9ghz
Perhaps mentioning what heatsink you have would be better (as that may be the problem of the high temps).
As for thermal paste check stulid's thermal paste comparison thread to see which is best (I think the MX-2 or Gelid one won).
Definately working very well for me.
Was surprised how big a tube they supply. Not a lot in it, but enough for a couple of installs
