Deleted member 251651
D
Thanks for info, are there any risks associated with the other 2? Thermal Grizzly Kryonaut Extreme Performance and Thermal Grizzly Kryonaut High Performance Thermal Paste?Stay clear of liquid metal if you can anything conductive is a risk unless your ok with that. The kryonought range are excellent and will only be a couple of degrees between them.
As far as im aware there both non conductive but best to check to confirm.Thanks for info, are there any risks associated with the other 2? Thermal Grizzly Kryonaut Extreme Performance and Thermal Grizzly Kryonaut High Performance Thermal Paste?
How many ml would be sufficent for 1 application on cpu?
TYI
I did a test recently between H2 and Kryonaut and the Noctua thermal paste was consistently a few degrees better.Noctua NT-H2 is my go to for premium stuff that lasts years. Always wanted to try Alphacool sub zero or apex though.
I just use use a small blob in the middle, they are all within a degree or two of each other. But yeah, TG is very expensive and the extreme version is just silly money.I did a test recently between H2 and Kryonaut and the Noctua thermal paste was consistently a few degrees better.
It was easier to apply as well making the ThermalGrizzly paste distinctly overpriced and overhyped!
