- 23 Mar 2011
- Devon
Should be buying a TV for the front room this week.
The current one is about 43" and is very early flat screen so no HDMI etc... minimum i would probably have is a 40"
Will be used with an xbox one and probably netflix so Smart would be a plus but not essential (depends on price difference)
3d is not essential, although I have a few 3d blu ray's i would like to use if possible, but only really looking for 3d if its a few quid more really.
im currently looking at the Samsung 40h6200 40" as its priced at £379 in an Argos store near me (last one in stock and 20 miles away) and seemed like a good spec and size and came with the bonus of 3D should i want to use it.
Does anyone have any suggestions? only really looked to spend around £350, cheaper the better but without affecting picture quality (i remember Samsungs being the best for picutre?)
