- 8 Apr 2013
So I have a faulty tv which needs to be exchanged. I can only go to Argos and I was hoping I could get some advice from some pros?
I would like it to be under £500 as my other model was £400 (can't afford to put anymore than that towards it)
I wouldn't mind something bigger than a 42 inch. 48 or 50 would be nice.
Not sure if you are allowed to post links from other shops here so I will just say the model and price
Sony KDL48W705C 48 Inch £469
LG 50LB561V 50 Inch £499
LG 50LF5610 50 Inch £499
LG 49LB5500 49 Inch £379
I'm not after the cheapest.. I'm after quality.
I have bad luck with tv's and they always tend to have problems so if there is a safe option I will have that please
Thanks in advance!
Thanks in advance!
