Best undies to help stop Chafing
Zip
Zip
26 Jun 2005
Australia
Im about to go fork out some cash on on new undies(underwear)
Im wanting some good ones that will help reduce chafing because when i run first my Gooch and the back of my sack chaff then eventually my inner thighs then to finish it off if im going all day for a hike or similar my Arse cheeks chaff :o
So what are the Best style of undies, The best brands and the best fabric.
One requirement is that they are made of a natural fabric and must be comfortable to wear all day so no bike shorts or compression tights:)
Thanks:cool:
Do you wearing loose boxer shorts when exercising?
Boxer briefs are what you need, they fit without being tight.
Fool proof.
If you're wanting them for running get some proper running shorts with lining.
Im stocking up now because im off to the Army in just over a month, so they wont be used for just running and i wont get to choose what shorts i wear.
Ive been wearing some Hole Proof and bonds Boxer Brief(trunks?) and they still give me the nut rub.
I accidentally ran commando last week and **** that was uncomfortable. I felt like i had a Pendulum down there:p
I prefer at present LR brazilian shorts, but i don't think they'd be quite what you are looking for.
Gotcha.
Get some high wicking ones.
Any brand or Materials come to mind?
Hows bamboo for a material?
I have have some bamboo socks i use for work and they are incredible comfortable and just dont smell at all after a hard days work. The only problem is after you wash them it takes an age to dry them but that might be because of the thickness,
