Hi all,
The AMD vs Intel controversy has been maddening. I had decided to go the 3700x route, but because I want to play around with Hackintosh, I have decided on Intel.
Can anyone spec me a 9th gen or 10th gen build please? I’m look to install Windows for Gaming and Mac for video editing. What’s the most reasonable build? 10900K seems very overpriced for the benefit it has over e.g. 10700K (correct me if I’m wrong here). Is there a meaningful difference between 9th gen and 10th? Or is taking advantage of the lower prices on 9th gen the wiser choice?
I would also like a recommendation on how to create a silent as possible PC. I heard that 9th gen ran much hotter than 10th - so was thinking that the 10700K would be the best bet.
As you can tell, I’m quite confused. Any help would be appreciated.
Thanks!
Thanks!
