Best value low capacity SSD?
20 Oct 2008
I've got an old Acer F200 laptop the wife uses.
It ended up up with one of my olds SSDs in it (Crucial C300 64GB). It's kept the laptop very usable but it's now full.
What's the best 'value' SSD at the moment? It doesn't really need to be much over 100GB.
Edit: The problem has gone away. I've remembered that I've got a 128GB Crucial M4 I can rob from another PC.
On the M4 make sure the SSD is on the latest firmware as I think there was issues with them reaching so many hours being on.
Is clearing it out an option?
Run CCleaner, disable system restore, run Disk Cleanup.
Run Treesize Free and manually remove large files/folders.
You can quite happily run Windows on a 30GB SSD if you keep on top of things.
