Which waterblock out of these would be the best?
Alphacool HF 14 Yellowstone copper edition sockets 775/1366/1156 Product No.: 10366
£35.39
Watercool HK CPU LGA1156 Rev. 3.0 LT - White Product No.: 10342
£44.01
EK Water Blocks EK-Supreme HF Plexi universal (775/1156/1366/AM2/AM3/939/XEON) Product No.: 10334
£51.63
or would another block be better? (suggest one)
Also, would I be able to get a bracket to use the alphacool and watercool with an AMD socket?
£35.39
£44.01
£51.63
The one you fitted was the plate that used be fitted as standard. They changed it to the single slot plate after all the reviews complained about them fitting the plate with the worst performance. I went for the two slot plate as i felt it was the best compromise between performance and restriction.
