- 14 Jul 2005
- Bristol
Dashik said:You can either drive or you cant![]()
I dunno, some testers seem to be getting really leniant these days...they say people can drive, but really they can't.
InvG
The Edge said:Were you fussy about your test centre, or did you just go anywhere?
Out of preferance i'd like the same centre on the basis that i know most of the roads. I knoe "You should be able to drive on any road....." but I failed the test basically because i didn't know where i was going and crumbled a bit under pressure.
I'll keep ringing thanks![]()
, good luck with your future Driving lessons/test.Dashik said:Everyone makes mistakes, The thing is is to relax and try not to do the same thing the next time. Perhaps you might have been a touch fast on approach and not given yourself enough time to look ahead and plan your route across?
. It's now tatooed in my head
