Not got any pics (They can be found easily on google) But the die on the Skylake-X cpu is about the same size as 2 x sandybridge cores sidebyside.
A little bigger, but not anything like Threadripper.
Skylake-SP Die Sizes
Arrangement Dimensions(mm) Die Area
LCC 3x4 (10-core) 14.3 x 22.4 . 322 sq mm
HCC 4x5 (18-core) 21.6 x 22.4 . 484 sq mm
XCC 5x6 (28-core) 21.6 x 32.3 . 698 sq mm
Bloomfield die is about 263 sq mm
Sandy Bridge E dies is about 435 sq mm
Haswell SSE dies are about 661 sq mm
Nehalem EX die is about 684 sq mm
Threadripper dies are about 191 mm sq each with all 4 (2x dummies) setting in a 1519 sq mm
The above data for Googling shows new Intel similar to older Intel. I didn't look at what the IHS sizes were, but assume in the 40-43 x 40-43mm range.
Each Threadripper die is almost as big as smaller Intel dies .. and each die is spaced about 11mm from it's neighbors. But Threadripper PCB is more than twice the size of any Intel.
