Best way to kill a computer
4 Feb 2007
Nuneaton, UK
We have an old pc at work that is really slow, is it possible to make it break without actually doing physical damage to it?
Its so slow and useless to work with, they wont replace it unless its broke. Its an AMD Duron 750mhz with 128mb ram, a workmate disonnected the cpu fan but it just keeps running, been like that for a week now.
Any suggestions? Needs to be broke without visible signs of damage.
Cheers
i thought that, not sure how it clips on thou, i'd be worried it wouldnt go back on.
we ran Prime95 on it for a bit but didnt really have enough time.
mr_x_plosion said:
Do any of those programs not require an install?
As we dont have admin rights and most things wont install.
Oh right forget that then :D.
Just d/c the HSF, up the volts to its max and run Orthos. It will soon die.
lol, i considered switching it to 110volts but i think the explosion will attract too much attention.
I think blanking the HD will just get IT to re-install.
Most of the caps look like they are ready to pop anyway.
I'll have a look in the bios tomorrow, hopefully I can give it some volts, otherwise I might have to induce my own with a variable bench psu. :p
Thanks guys
MikeHunt79 said:
Wee on it while it's running prime95 ;)
Then do a 5curler on the keyboard :eek: :D
and kill yourself :D, put a very high demanding game/demo on a usb/cd and play it on a very high res while running orthos, killed my old celeron doing that.
send it to me... ill mess it up for ya... why dont u just wave a magnet over it while its on... will cause a fire... do NOT attempt
stickroad said:
Open the system up, stick aload of powerful magnets in their, close it all up, get a really, really long stick stand back and turn it on.
nice... u can read my post :)
Yea the magnets will add a lot of weight to the case and do....nothing. Why not secretly put another 128 or 256 RAM in there? seems like the biggest bottleneck.
