pumaz said:Install Vista![]()
lol!
especially as its not gonna cost you anything. Try lapping the cpu little bit to hard, just tell the it staff you wanted cooler temps...a.hay said:Just try and short something.
mr_x_plosion said:Another department of this company makes computers, they arent short on cash and will get them dirt cheap anyway.
We cant build up static as were standing on ESD floor lol.
Leporello said:Perhaps you could get a job in a computer store where you could play with all sorts of exciting hardware?![]()
try and create a business case if you really think you need a more powerfull pc.tsj said:put your pc in microwave and turn on..
close all air gaps on ** case to trap heat.
Amonlym said:its an old duron. its never gonna die. ever.
amd sold a lot of their staff and the staff's families to satan, who then forged those cores in the fires of the bowls of the earth.
from huuge granite slabs.
or something.....
more seriously - way uncooltry and create a business case if you really think you need a more powerfull pc.
but for most "work" (word, excel, e-mail) you could make do with an old pentium 133 and not suffer unduely.
as someone else said, try and get some more ram into it and ask for a re-install to speed things up.
ots3go said:Not working anywhere for DSG are we?
Bah, I know I've already suggested it once, but a bad BIOS flash is all that's needed.MikeHunt79 said:flash a BIOS from a random motherboard - it won't boot then
use the /force![]()
MikeHunt79 said:Then do a 5curler on the keyboard![]()
