Some diluted water and a lint free cloth does the jobs fine.
stack some books and prop it against it, you haven't said what angle you wanted it to lean at though but I figure you can probably adjust to suit.
Diluted water![]()
If its badly scratched... 'T-cut - Lite' and a soft cloth... fixed my GTA disc on my 360![]()
You mean you don't dilute your water? You use it straight out of the tap!!!!??
Yeah of course, diluting is for wimps. I find water from the bathroom tap better than kitchen, suppose you could mix the two but I'm not that hardcore.![]()
im trying to install AOEIII on my new pc and did try on my old one and keep getting ero 1305 so im thinking it must be the disk, anyone have any suggestions?
BTW title meant to say clean
Do you live near a large blockbusters store (surely I can name that, it's a DooVDe rental store, not PC supplier)? My little brother worked at one and they have a disk cleaning service. Costs about £2 per disk but can recover them from almost any scratch. wont work it the disk is actually cracked or if the scratch is so deep that it has gone through to the foil in the disk. Works like a charm.
