I'm getting a new system soon but for now I really want to overclock my AMD FX 4100 as it is really the worse part of my set up.
What are the best programs and ways to overclock, a step by step guide would be great as I can't find the option to self increase the multiplayer in AMD Overdrive... I can only seem to overclock after running a test and applying that test. (e.g. last safe clock was 4.4.ghz) The problem here is that when I apply that clock it isn't safe as the screen goes blank before the test ends and I'm actually applying an unstable clock.
I really don't want to use the Auto Overclock on the motherboard as it doesn't even touch my GPU. I can overclock the GPU safely way higher than this auto clock does.... the auto clock takes me from 3.6GHz-3.8GHz which I think is poor and surely I could get around 4GHz if not higher?
AMD 970A-G46
• All Solid CAP
• OC Genie II: Easy Overclocking Technology
• Support USB 3.0 and SATA 6Gb/s
• Lossless 24bit/192kHz HD Audio
AMD Bulldozer FX-4100 Socket AM3+ 4 Core Processor - 3.60GHz, 3.80GHz Turbo
CX430 — 80 PLUS® Bronze Certified Power Supply
Limited Edition Red OCUK Ram 8GB Kit @2400MHz
Vengeance 8GB DDR3 Memory Kit @2400MHZ
Thanks guys
AMD 970A-G46
• All Solid CAP
Thanks guys
