As title.
I've got a crappy 14" CRT Telly to play my Gamecube on.
The best screen I own is a 19" Viewsonic TFT Monitor. I'd very much like to play the Gamecube (Specifically the upcoming Zelda) through this instead. The 19" Dell CRT Monitor would be preferable too.
I know the 'Cube doesn't support this out the box (It's a recent PAL one).
I've seen 2 options :
- A Logic 3 Converter Box where you plug in component / S-Video from a console or DVD; it converts to VGA (Can't link, I think ? or is console stuff OK ?) This doesn't need to have the PC on but does anyone know what the quality's like ? If you've used one (for any console) what's it like ? does it support 60HZ too?
- My X1800XT has Avivo functionality. Obviously the PC has to be on for this. I'm sure by some cable blaggery I can input the 'Cube through some format to this then to the monitor. Any experience with this way for any consoles ? Is it easy to get full screen ? How's the scaling ? (AND how the hell would I do this ? - Re software)
Any hints will be very much appreciated.
