I've found vidahost to be the cheapest when buying .co.uk domains, other than that I usually use namecheap.
Try hard to avoid registering a domain with a hosting package as they can make your life a living nightmare if/when you wish to change hosting.
What if you do happen to want hosting and aren't simply reserving a domain name for possible future use; with whom would you recommend registering then?Just use a domain registrar like GoDaddy or NameCheap.
