Thank you.
According to the specifications https://www.asus.com/us/Motherboards/H170-PRO-GAMING/specifications/ it has 5 fan headers in total - CPU, CPU_OPT, 3 x Chassis/Sys_Fan.
The Intel stock cooler will be using the CPU_FAN header, I presume?
Rear fan can go into CPU_OPT.
Two top fans can go into 2 x Chassis/Sys_Fan headers.
And the three front fans can go into the remaining Chassis/Sys_Fan header, with the help of this 3-way splitter:
My basket at Overclockers UK:
The description for the splitter states it also works with 3-pin DC fans.
Tip: don't have the two top fans running as fast as the others, or they'll exhaust cool air (I'm assuming they exhaust) before it washes across the motherboard and CPU. Given you have 3 front fans, those may not need to spin too much either, with their combined CFM. The one I'd want faster than the others is the rear fan.
Like Brizzles said - if you encounter any issues with CPU temps it will mean the stock cooler itself isn't good enough for your chip.
Thank you for your detailed comment I will order this splitter and try out the way u have described to do it.
