I have had a brand new replacement fuel tank delivered, to be fitted this weekend. It's been zinc coated and sprayed silver and I wondered if there was a product I could use to prevent it rusting in the future? Any ideas? Cheers
If you fill it with petrol that will stop the inside rusting.
Fuel tanks for road cars generally aren't universal items, so it's not always straightforward to get a plastic one. They aren't always lighter either, plastic tanks are significantly thicker than steel ones and weigh a fair bit in my experience.Get a plastic tank, will be lighter too.
