best wheel for 360?
16 Sep 2003
House
so what's the best xbox 360 wheel for under £100? looks like the microsoft wheel is the one to go for but anyone disagree? any others any better? cheers :)
To be honest there aren't any others if you are looking sub £100. In that budget, the Microsoft one is best, but if you are looking to get the full experience (and have the cash) consider the Fanatec (Mr Latte has done a review on all of the top end wheels) but it's ~£300
Yeah, the MS one is the only real option other than the Fanatec, but note that the pedals are dire, especially so if you come from a decent set like the G25...
Yea, I find my pedals a bit of a let down. Does any one know if third party pedals are supported in anyway? I find mine are useless at gripping the floor and aren't particularly 'ergonomic'
i agree wholly about the pedals, they are too slippery and spring loaded as opposed to gas so don't feel authentic in any way, the wheel is a whole different story though, i really like it, the feedback is great too.
I see that you can connect the G-25 pedals to the Microsoft wheel by knocking together a reasonably simple adapter. Might be worth considering if you have both and the Microsoft pedals are that dire.
Get the logitech driveFX as its half the price of the MS one. Think i paid £17.99 . When it launched it was around £60 its been discontinued
I have owned both and the build quality and pedals from the MS one are gash!!
Feedback is much better on MS one though
