- 29 Aug 2010
- Cornwall
I'm currently using a Silver Arrow with stock fans. It's not the coolest running chip I've ever had, but it does have 6 cores (3930K).
Now as many of you with a X79 probably know, there's not a lot of room between the top PCI-e slot and a number of CPU coolers.
I'm using a Rampage IV Extreme, I'm not sure if this has more or less space than other boards.
The gap between a graphics card in the top slot and the heatsink is a few millimetres if you count the fants as well it may be about 1mm.
I'm looking to get a slightly thinner cooler that will match the performance of the Silver Arrow.
I've been looking at the Dark Rock Pro 2 and the Phanteks coolers. Both seem to be a few millimetres narrower, but also both seem to have bits that stick on on the fan clips.
Does anyone know what sort of room you have with these? any pictures?
The other obvious solution is something like an Antec Kuhler 920 or Corsair H80/H80i. They easily solve the space issue, but are they up to the cooling performance of the Silver Arrow?
It's going to go in a TJ11, which I do expect to watercool, eventually. But I want to get everything in the case and running so I have a better idea of the space I'll have (trying to decide where to put the pumps). I'm not sure how long I'll run on air, if things are cool and quiet enough I may stick with it for a while, so I want a decent solution.
Thanks for any suggestions.
