I'm certain that's what's in there so that should be OK. In fact it's definitely 400FSB because the clock is 200@10 and it's got DDR RAM. I've just sniffed about and it appears that people are paying fairly big money for these CPU's. Ouch!MeatLoaf said:Fastest you can get is a Barton 3200+
But you need DDR 400 RAM to run it and a mobo that can do 400FSB
steve258 said:Mobile AthlonXP-M 2500+ is very popular.
Motherboard is Asus A7N8X-X NForce2 400. The current XP2600 is at 200@10 and sits underneath a massive Thermaltake cooler. It runs OK at 200@12 but get the odd blue screen so I leave it at 200@10 for rock solid use. I've been out the O/C loop a while so wouldn't go messing with volts or RAM timings too much but if the mobile processor can go better than 200@12 on air and still stable I'll probs go for that. However, the market for these processors is shocking. People are paying over £50 on some other website.postmanfw said:What motherboard does it have?
Def best to get a mobile as they go for about half the price of a xp3200, clock much better and remain cooler in the process.
The multi is unlocked upwards on the M version, was the E6300 of its day.steve258 said:Mobile AthlonXP-M 2500+ is very popular.
HangTime said:I remember there being some Socket A Semprons, the top end one of those is probably the fastest. I guess it would need a BIOS update though.
stigggeh said:cheapest (and best imo) option might be to grab a second hand A64 and AGP board
Athlon XP's are going for more than low end A64's now so i recon you could do that without spending a penny (after selling yours)
