Better Latency or DDR3 Mhz Speed?
21 Dec 2005
Which would be the best OC settings for gaming with the Patriot Viper 6GB (PVT36G1600LLK)
Is lower latency better than a higher Mhz speed?
For example this ram can be overclocked to either:
8-8-8-241T 1866Mhz
7-7-7-201T 1600Mhz
What would be better of the two settings:confused:
I'd be tempted to go for lower latency, but there's not much between them. What would happen if you zap them with more volts? Might be able to get higher speed AND lower latency?
8-8-8-241T 1866Mhz
7-7-7-201T 1600Mhz
This can also vary depending on your specific usage. Test it both ways doing what you built the machine to do. A synthetic benchmark may not tell you what you want to know.
Well I actually have zapped more volts and have had it running fine at 7-7-7-201T 1866Mhz. My gaming room is really cold at the moment not so sure if it would be stable when the cold months has passed though.
I do a lot of things on the PC but most importantly for me is online gaming, just want to squeeze every bit of performance speed out of my system so I dont perform badly during clan matches. Lots of pride at stake;)
I also notice no difference between the two different settings but wanted to know from you experts as Im new to memory OC'in and the whole CAS timings and Mhz speed is confusing me.
For now I'l just run them at 7-7-7-201T 1866Mhz hopefully will be stable throughout.
Thanks for the answers:D
On paper there's not lot in it.
if you convert the timings to actual time units you get (in ns)
4.29 - 4.29 - 4.29 - 12.86
4.39 - 4.38 - 4.38 - 12.50
you'd need to bench it to work out which is faster fro what you do.
2000mhz at 9-9-9-27 - 9.0ns 16,000MB/s
1600mhz at 7-7-7-20 - 8.8ns 12,800MB/s
Calculated as 128-bit for bandwidth but if 192-bit the same pattern would emerge!
pick whichever option suits you best, bandwidth for Max-Power Encoding and the like and lower latency for day to day use! :)
You will only noticed increased bandwidth if you use it, whereas decreased latency is always working . . . 2.0GHz cas 8 would give you the benefit of both! :D
2000mhz at 8-8-8-27 - 8.0ns 16,000MB/s
dont over think it, i did loads of tests on my system with different very different timings and speeds and noticed nothing different at all.
save your money go 1333 7-7-7-20 or 1600 8-8-8-24
