Better than a h105?
Beat it how? It is a custom loop with a better radiator, better pump and arguably better CPU block also. Comes with the usual custom loop vs CLC things also- maintenance, expansion, installation etc.
As above, it will give you better performance and more customisability/upgrade options but it does need maintainence to retain that advantage. If you feel comfortable with a custom loop its a great option. The H105 takes the hassle of setup and maintain ence away, which is why the h105 is such a popular option.
H105 is a good option but i dont get why people dont wc the graphics card also, as that tends to be the noisiest part. Going custom loop lets you add a gpu block later, plus its fun !
