BF3 lag
AMD Phenom II X4 B50 Processor @ 3.5ghz
AMD 6850 CF
4GB Kingston hyperx 1333mhz DDR3 ram
Asus m4a785tdv-evo Motherboard
Coolermaster silent pro 700w Modular Power supply
ocz agility ssd 60gb & 80GB Sata Harddrive & WD 1tb
Sata DVD-rw
Asus royal knight cpu cooler
ive tried both high and ultra and changed various settings but still getting the spikes 1680x1050
Do you know what your CPU usage is?
Try overclocking it some more, also overclock the CPU-NB to 2600 / 2800 Mhz if you can. see if that helps.
Overclock your processor.
You can also try this.
Create a user.cfg (save as all files not a txt file) file and place it in the battlefield 3 main folder.
Copy and paste these commands in the config.
RenderDevice.ForceRenderAheadLimit 1
RenderDevice.TripleBufferingEnable 1
RenderDevice.VSyncEnable 1
gametime.maxvariablefps 59
Does that improve your situation?
Could be cpu bottleneck because of the 1680x1050 res, if you know anyone with a 1920x1080 ask them them if you can test your pc on it.
AMD 6850 CF
Sata DVD-rw
I can tell you right now you are maxing VRAM. You can run High on 6850's easy, but kill the AA! The rest of your rig is fine brah
ive overclocked to 3.6 now and im not sure about the cpu/nb because i cant actually see the mhz, theres just multipliers? what shall i put it on? cheers
tried new drivers and even on low settings im getting fps drops and spikes :/ doing my head in now
The CPU-NB is a multiplier, i don't know your motherboard so i can't say where or what it is.
I think you have a CPU bottleneck.
Overclocking it on Phenom II's will give you about 10% higher performance.
Can you run it at 1920 x 1080? if so do it and set GFX to high with no AA
Just tried this , still no luck :c thanks though!
Hit the ` key, then type RenderDevice or part of it and you can hit Tab to auto complete, then you start typing ForceRenderAheadLimit or part of it and you can hit Tab to auto complete that part as well, if you then hit Enter without adding a numerical value, it well tell you the current running numerical value.
Do that for all 4 one at a time.
just done this, seems that the config didnt work for some reason? but when entering these into the console the game did run a bit better, less lag spikes but still getting them, moved settings down to high but still getting a disapointing 40-50 fps on big maps
Download this file and place it in your battlefield 3 main folder.
http://www.sendspace.com/file/fm5q61
