BF3 Settings Help
10 Feb 2012
North Ayrshire, Scotland
I've been playing BF3 a whole lot recently, but my PC is not up to the recommended requirements. (My GFX (560 SE) Is a tiny bit off, but my CPU (E6600 Dual) is WAAAAY off).
With everything on ultra on 720p (I always play 720p because it suits my eyes best) I get around 25-35 FPS but it sometimes drops as low as 20 FPS
What settings could I change to give me higher FPS without an upgrade (yet)?
I tried AA off but it didn't make a massive difference. Only about 5FPS increase.
Please help :(
The three big things that always seem to make the most distance are shadows, draw distance and AA. I can't remember what options BF3 has off the top of my head though.
Shadows often make a HUGE difference and have minimal impact on gameplay. Try turning those down/off first. The only time they can affect gameplay is if you see a shadow coming around a corner, that's very rare though and you'll still see it with the lowest quality shadows anyway.
Draw distance can make a big difference too but obviously it might put you at a disadvantage if you can't see someone shooting at you because they're too far away.
You say you've tried turning down AA, so you know the effects of that. If you're dropping to 20fps, that extra 5fps sounds like it's worth having though.
Yeah, BF3 doesn't have draw distance. I will try turning shadows down though. :D Thanks for the reply
Bf3 does have draw distance its called mesh quality! Just turn everything off I play on a top PC and still run bf3 on low settings!
