BF4 Issues ONLY survey
29 Jun 2012
if you have an issue with BF4 beta let me know what it is and the spec of your PC
I'm trying to conduct a survey to see what everyone has etc and report back my findings. This is being done accross more than one forum so will hopefully get some good results for you all.
processor
GPU
Ram
core i5 760@4ghz
7990@stock
2x4gb corsair Xms3 1600mhz
W7 64bit
get poor FPS on all graphic settings and very laggy gamplay
core i5 760@4ghz
7990@stock
You have the mother of all cpu bottlenecks going on there Beasty. Even one 7970 would be bottlenecked on that cpu, yet alone two.
Ok, just saying that the info's there and has been discussed at length :)
What were you going to do with your findings btw?
Taking them to David Cameron!
Well first i was going to make a pie chart and then i was going to procrastinate a little.
Feedback to Dice via an analytical report im trying to produce in order to full-fill my further needs in the world and community i so crave the attention for
That's very honourable :)
To aid you in your quest:
CPU: 2500K
GPU: 7970
RAM: 16Gb
OS: Win7 (You may want to ask for this too, as it's proving to be a major part of the equation)
Plays fine, but can stutter to single digit fps every now and then.
Btw, Dice have a thread on the BF forums that asks people to post their dxdiag reports for their own troubleshooting purposes.
i5-2500K @4.5Ghz
8Gb DDR 1600Mhz
Win7 64bit
GTX 680 2Gb (331.4 beta drivers)
Stutters every 2 seconds or so despite good frame rates, perfoverlay graph shows CPU and/or GPU usage spikes to be the cause. This occurs at any detail settings.
FX6300 @ 4.6
HD 7850 @ Stock
XMS3 1600mhz DDR3 corsair ram 4 x 2GB
Low FPS and laggy gameplay no matter what settings or res i try.
CPU: i5 4670K
GPU: HIS IceQ 7950
RAM: 8GB
Laggy gameplay but a massive problem for me is when the game just freezes and I have to exit out completely and says the program has stopped working. Not just me either its happened to a friend at the exact same time in game.
i5 2500k @4.97ghz
Asus GTX 690 @ stock speed.
2x8GB HyperX Black Edition DDR3
Nvidia 320.49 drivers because it is even worse with the latest Beta drivers.
Game stutters all the time, random fps drops down to around 1-2fps especially when rocketed or shot at in general, random CTD's for example using the sniper spotting bino's = instant CTD. Major archifacting on CTD's.
System completely stable passes all tests at that overclock, has been on that overclock for over a year, no other issues in any other games in Dishonored, Crysis 3, etc.
Good idea tbh - always put OS please as this was a major factor
Intel i7-3630QM
GTX 675M
16GB RAM
Win 8, x64
Ran fine at 40-50fps low settings. No stuttering.
Of course I couldn't hit Ultra with M-GPU ;)
