BFBC2 benchmarks
I was running it on an 8800gt up until yesterday, rest of my rig is an i7, 6gb ram, (currently at stock) A quick bench using fraps listed, min 19fps, avg 39fps, no aa/af, res at 1680x1050 (dropped from my native 1920x1200) running under directx 9 on win7 64. Ive replaced the 8800gt with a gtx 275
as per sig, all at stock. 1920x1080 res.
In game settings:
Level of detail; High
Texture Quality; medium
Shadow Quality; medium
Effects Quality; High
AA 2xMSAA
AF 4x
Vsync; on
HBAO; off
depending on whats happening on screen fps between 30-60. very occasionally dips to low 20's.
Same system here. I've been testing another 275 sli. running 1920x1200 everything max DX 10. runs sooooooooooo smooth.. worth the upgrade :)
One 275 just dont cut it really.. :eek:
On my current 275 (640 core clock xfx version) i run it on high at 1920x1200, 2x aa, 4x af, hbao off, runs pretty well, i could go sli gtx 275 as a friend has offered me another identical card, but i think ill give it a miss, probably get myself a couple of 5870's and give crossfire a try, bit peeved off with nvidia cards lately, had a gtx 280 die then the first replacement 275 died as well, but ill whack my i7 back to 4ghz tomorrow, maybe try a quick oc on the 275 and see how bfbc2 fares. But so far the 275 is a bit of a let down compared to my old 280.
What this game really needs are some reliable numbers, especially with crossfire and dual/quad comparisons.
Not from my experience, my current 275 has the same core speed as the 280 i had, but there was 1gb of ram on the 280, 896mb on the 275 gtx, cant compare on bfbc2 as i never got to try it with the 280, but in all my other games the 275 doesnt run as well as the 280 did, theres not much in it, but i definitely notice a drop in performance. Ill load up my oc profile for the cpu at 4ghz, then see how it compares, bu currently with my i7 at stock it seems quite a bit slower than my rig was at stock with the old 280, but it does run a wee bit cooler.
I was thinking of 2 Asus 5850. but i read a lot of people we're having very slow loading issues in BFC2. not sure if anyone else does.
I tried a 5870 with rfactor. for some reason it stutters like mad, put my 275 back in, and was fine. think the nvidia card suit rfactor more:rolleyes:.
