Hi,
I've recently been having problems with my BFG 8800GTX "black screening" and sometimes nvlddmkm.sys blue screening after a while in games.
I have reinstalled Vista and tried everything I can possibly think of.
I then decided to download nTune and manually stick the GPU fan speed up to 100% as well as take the side panel off my PC, this took off about 20oC (from ~82 in games to ~62
). I have the Lian Li PC-7 II case with 2 120mm Yate Loon fans & a Scythe Ninja.
The GPU never went over 84 so I was assuming that was fine which is why I never suspected heat.
Anyway, today I must have played at least 2-3 hours of Titan Quest (if you know this game you'll know it makes your GPU very hot) with no crashes, the temperature maxed at around 65 with 100% GPU fan speed & side of case off.
Anyway to my question... could a chip that isn't monitored maybe be overheating causing the crashes? Could the graphic card somehow be configured incorrectly to panic when the GPU gets to ~85? Any ideas?
I really would like to put my side panel back on and not have to manually put the fan speed to 100% every time I want to play a game, I shouldn't have to...
Thanks,
Craig.
). I have the Lian Li PC-7 II case with 2 120mm Yate Loon fans & a Scythe Ninja.The GPU never went over 84 so I was assuming that was fine which is why I never suspected heat.
Thanks,
Craig.
now that is noisy.
. Oh, I also have a 92mm fan lying on the back of the GTX blowing on the back of the core. I've had it on there since day one so I don['t know if that has been helping.
tbh
