Hi all,
Got a bike that was taken apart a bit to clean up and service a bit. Now when it is all fitted back, if you apply the front brake and rock the bike forwards and back, you can see the whole part where the handlebars join the fork section is loose / wobbling despite screw at the top of the handlebar being tight
Anyone know a possible fix?
Hopefully the explanation made sense
Thanks!
Thanks!
