Just powered up a new build, decent quality parts and all settings at default.
After about 20 seconds just as I was about to start installing the operating system when there was a very loud bang.
After I let go of the ceiling I checked out inside the case and could see nothing wrong.
Of course the psu was the prime suspect so I decided to take it apart but on inspection found nothing.
So I popped in another power supply and everything powered up no problem.
Lucky you may say, I thought so as well until attempted to restart the new install of xp.
I had booted to the dvd and nothing, so I hit the eject button and found........
http://img519.imageshack.us/img519/351/clipboard01ra.jpg
I have never seen anything like this before - have you.
