Having just sent my board back i have had to remove the CPU and Heatsink/Fan from it(duh
The HSF is a artic cooling freezer pro 7 with the bog standard thermal paste which comes pre applied on it, but now i have removed the cpu and hsf and taken them apart, will i have to buy some more thermal paste from somewhere and reapply or is it ok if i just don't bother and use the existing bits left on the hsf/cpu?
Another question is what is better...Arctic ceramique compund or arctic silver 5? Someone told me that AS5 evaporates after a couple of months so i'm not sure which to get.
Thanks.
).The HSF is a artic cooling freezer pro 7 with the bog standard thermal paste which comes pre applied on it, but now i have removed the cpu and hsf and taken them apart, will i have to buy some more thermal paste from somewhere and reapply or is it ok if i just don't bother and use the existing bits left on the hsf/cpu?
Thanks.
