Ok, my setup is in my sig so i'll not repeat it... but I was wondering if I have a serious problem or just a case of using the stock fan.
I have a coolermaster CM690 which is fairly big, and it has a fan on top blowing up, one on the side blowing out, one on the back blowing out, a huge on on the front bringing air in, then obv the graphics card and CPU fans.
It idles around 46, and after running prime95 I just got to 95 within 10 mins. That's really not good i'm sure.
So... Are temps like that normally due to other problems? Everything is at stock levels and I can see no reason it should get THAT hot. It does however have the stock CPU fan... but 95 within 10 mins!?
I am considering the Corsair H50, but should the stock fan be so... toasty... or is it likely there are other problems too?
