Big problems help!! Default administrator password??
10 Dec 2006
Hi,
Just been fixing a friends PC after loads of hassle Ifinally got it sorted. Unfortunately all this work is about to go to waste if I can't get past this problem that has just ocurred.
I edited the boot file for windows to sort out a prompt during bootup and I cannot now boot into windows I get a big error message. "Windows could not start because of a computer disk hardware configuration problem..." etc.
I have booted from the Windows XP install cd in an attempt to run the recovery console so that I can gain access and sort out the boot issue in windows. It has prompted me for the administrator password which I haven't even set anyway. I have tried "password" and just hitting enter and this doesnt work. Does anyone know what the default administrator password is or a work around this please?
Totally desperate here, hope someone can help. Thanks
if you havnt set the password, would it not just be blank? as in your just press enter when it asks for it. - o sorry, mis read what you said then, sorry!
Yeah odd that. As a side note I have just solved it, I havent found the password but I'm in windows with no problems. I ran help in DOS and then managed to reset the boot to look at C/Windows :)
