Big Problems
9 Oct 2008
Somerset, UK
Ok this morning i made a post about my computer clicking well now i got more problems. =( I will start from the begining =)
This morning i get windows updates, i restart my computer i get a BSOD when my computer start back up i try again press Start Windows As Normal no problems windows comes up fine. At this point there has been a clicking inside my pc for days which i believe to be my HDD but i'm still not to sure. I ran HDTune and my HDD results are AWFUL. Also i heard this clicking noice i hear as my computer starts up and shuts down then all of a sudden my pc clicks and it turns off. Then i open up my case and notice that my fans on my Graphics Card are not spinning (using a ATI 4870 with a Arctic Accelro Twin Turbo Cooler) i turn the fan with my finger see if i can get it going but it wouldnt move i then notice my GPU was at temps of 102C on the memory .. =(. So i put a desk fan on my GPU and it seems to be ok. Then with the custom cooler still on i hooked up the stock fan which still works. I also used the 3pin GPU fan to molex adapter with the Arctic Cooler still no luck so i guess that broken after a few months =(. Also it seems like my HDD is on its way out i will soon order a external HDD see if i can back it up. Its seems a little bit odd that this has happend at the same time and ideas ?? later i will be able to get my hands on another pc and swap parts see whats is and is not broken.
Ok whilst writing this post i ran HDTune again and now that i am using my onboard GPU my hard drive is faster on HDD tune before it was about 20meg max now i got about 130meg max =/
I'm am about to try reseting my bios see if that helps anything .. tho i doubt it also do you think this could be a PSU problem and maybe the PSU is clicking? its a corsair 620W.
Update I just restarted my PC for the onboard GPU Drivers and CHKDSK ran i believe it delted some bad sectors i wasnt really paying attention to my screen at the time. But saying that my HDD has gone dead slow again
Ok want to know if this sounds right .. I think it may just be a PSU becasue now i have taken out my GPU its not restarting at all. Also when my old PSU broke in the past the computer was very slow and would sit on shutting down forever as does this one atm.
