Hi,
Any thoughts on this?
I've just spent the past 4 hours moving my PC into a Antec P180 and a installing a Big Typhoon.
I was expecting a miracle in cooling however the CPU temp is only 4C better than stock @ the low case fan setting, 5C better at the medium case fan setting.
So in a warm room @ 24C my opteron 165 @ 2.4Ghz 1.35v is Dual Priming @ 46C.
I was expecting a little more in this case with this cooler. I've removed and refitted the cooler several awkward times, in the end I retained the retention module and screwed the bracket down to that. It seem physically stable and there is no movement in the fixings.
Previously in a cheap £30 case with PSU I was getting 50C Dual prime @ 1.35v using the stock opteron heatpipe cooler.
anyone else have a Big typhoon on a Dual core CPU ? would like to know some other temps etc.
Cheers
AD
Cheers
AD
