Tim said:Is your windscreen cracked?
Trifid said:.
How fast were you going on the first vid? Looked like 80/90mph from what I could see.
Simon said:I reckon normal brakes would have started to fade during this one stop. As we have had so many discussions with people doubting bigger brakes reduce stopping times I thought I may aswell post this of my car stopping
Save As
Oracle said:TBF, your old BRAKES (please people, if you're going to post comments about a subject you think you know about, at least spell it right!) probably would have stopped you just as quickly.....your tyres didnt loose grip after all!![]()
Simon said:Cheers for the comments.
Dave, They are a custom brake setup rather than an off the shelf kit: Wilwood dynalite 4pot calipers (1kg each) with 310mm x 32mm disks. I had the bells made up to a drawing and same with the caliper brackets.
With the braided hose fittings (fitted to the goodridge braided hoses i already had) and correct spec bolts and K nuts for fitting the disk to bell and calipers to the car it worked out at just over £500.
Bonus is that replacement pads and disks are very cheap. £30 a set of pads, £49 a disk
