Billion 7300G Wireless Connection
18 Sep 2006
I have just taken delivery of said router. Setup with desktop via cable easily enough but having trouble connecting to my laptop wirelessly. My laptop spots the network and signal strength is fine, however, in my "Network Connections" screen, the wireless network connection is always stated as "Not Connected". I'm sure I'm missing something simple but cannot figure it out.
as you can see it in the list, don't you just double click to connect?
and have you set up encryption - preferably wpa or wpa2. you don't want any old joe bloggs leeching your connection. :)
Thanks,
I had done all that. I've solved the problem by re-installing the software from my crocked Linksys... at least their software is reliable :)
Cheers
Andrew
