- 25 Sep 2020
I wanted to know what bin does it fall under for the Evga rtx 3080 black gaming, XC3, XC3 Ultra, FTW3 and FTW3 Ultra.
This post at EVGA's Forums says that none of the cards they are currently producing are being binned, so it is purely luck of the draw. They are howere apparently testing the overclock is reachable for the OC versions, so I guess there is slightly less chance of getting a bottom tier chip with them.
It means that it is definitely good enough to meet the advertised specifications and has a bigger and better cooler.
The XC3 Black is the basic smaller cooler without backplate, the XC3 is the same clock speeds and cooler with a backplate, the FTW is the bigger and better cooler and the FTW Ultra is a guaranteed overclock with the same composition as the FTW.
The current crashes and instability everyone is talking about only seems to happen over 2000Mhz core clock which none of the cards are advertised to do hence talk of needing a BIOS or driver update to stop them going so high. Different combinations of capacitors may help reduce instability at these speeds and EVGA have said that their higher rated cards with have the better 2:4 ratio whilst the basic cards will have 5:1 of the basic to high frequency capacitors
Why cant they just use 470 rated SP caps like the gigabyte 3080 eagle OC as this card has no problems with hitting over 2ghz. Tbh manufacturers are just cutting corners.
