13 May 2016 at 16:36 #1 cully4299 cully4299 Associate Joined 5 Feb 2016 Posts 234 Maximus ranger board. I5 4690k. Bios won't detect my m.2 just my sata ssd
13 May 2016 at 16:38 #2 snips86x snips86x Soldato Joined 14 Nov 2012 Posts 18,000 Location Chesterfield Remove & Re-seat? Also, make sure the screw to hold it in place is reasonably tight
13 May 2016 at 16:42 #3 andicole0 andicole0 Soldato Joined 12 Sep 2005 Posts 6,497 Location Grundisburgh Some motherboards disable M.2 if some PCIe slots are used, does the manual explain? Is it a compatible M.2 drive? Andi.
13 May 2016 at 16:51 #4 cully4299 cully4299 Associate OP Joined 5 Feb 2016 Posts 234 cant find where in my bios to enable the m2 setting. its a ranger vii
13 May 2016 at 16:55 #5 hyperseven hyperseven Soldato Joined 1 May 2013 Posts 10,110 Location M28 on the latest bios?
13 May 2016 at 18:59 #6 andicole0 andicole0 Soldato Joined 12 Sep 2005 Posts 6,497 Location Grundisburgh cully4299 said: cant find where in my bios to enable the m2 setting. its a ranger vii Click to expand... Check the manual but it is probably disabled when you use certain other slots. Andi.
13 May 2016 at 19:56 #7 Tute Tute Soldato Joined 24 Jul 2004 Posts 22,593 Location Devon, UK First thing to check is that it's on the latest version.
