ive seen loads of bios SS which actually show you your cpu speed,cant understand why mine isnt showing,ive done CTRL + F1 to show more options but does'nt show speed.
Nope. You may have to switch the machine off and back on again for it to see it. If Q-Flash from within the BIOS can't see it then try pressing the key combination for Q-Flash that's listed on the POST screen.
The floppy is the flash drive it just shows it as a floppy well on mine anyways, also f10 was abit flaky f11 is the latest none beta bios if your on v1.0 board
