- 1 Jun 2010
- Bedford
Hi guys I recently flashed my bios from F7 to F10 using Q-Flash on Gigabyte GA-EP45-UD3LR as I installed high end ram.
http://www.gigabyte.com/products/product-page.aspx?pid=2951#bios
http://forums.overclockers.co.uk/showthread.php?t=18234871
The ram worked perfectly fine and cpu-z and post screen shows the bios revision as F10 so it has been flashed sucessfully. However the problem now seems to be that I can't choose some of the options.
For instance while running memtest I couldn't choose configuration or even exit the program using ESC key. I had to press reset button on my case. Also I couldn't choose between starting windows normally or set up utility during windows 7 loading if I purposely pressed the reset button.
Edit: So if the 'starting windows normally' is already highlighted and I press enter, nothing happens and I have to wait till 30sec countdown
It seems for those kind of options when I try to choose them, Bios doesn't let me.
Any ideas
Any ideas
