Permabanned
- 28 Nov 2003
- Shropshire
I wanted to be able to hot swap drives, on a Gigabyte GA-Z97-GAMING 3 M/B. Seems the Gigagbyte BIOS has 3 SATA MODE SELECTION options:
IDE, AHCI and RAID. It was set to RAID, which makes sense as the D drive is a pair of matched SATA III drives in a RAID 1 pairing. C drive is an SSD with the OS on it. However this option doesn't seem to allow hot swapping, even though all drives are set in the BIOS with hot swapping enabled.
Setting the SATA MODE SELECTION parameter to AHCI doesn't allow booting, and I am afraid of enabling AHCI in the registry in case "something bad happens" to the RAID. What will happen if I both set AHCI in the BIOS and set the Win 7 64 bit registry for AHCI? Will the RAID1 Intel Rapid Storage Technology software RAID 1 pairing still work, and will I then have hot swappable drives? Thanks.
