Ok I'll start with basic system specs.
i7 920
GA-EX58-UD5
6GB G-Skill, 1600mhz, 9-9-9-24.
Nvidia GTX 260
Ok so my problem, everytime I restart my PC the BIOS resets and everything goes back to default, I go back into the BIOS and get the "your overclock failed etc". I've tried lots of different settings but it only seems to be happy on a completely default clock!
Now this problem only started to occur when I installed a PCI Express network card (Edimax EN-9260TX-E), before the card was installed I had no problem. I took card the out of the machine to test my theory and with the network card out it restarts and reboots without resorting to default, put it back in and same as before.
Could anyone shed some light on what could be causing the PCI Express card to do this?
Also there is a menu for the network card (pictured below), don't know if any of the options could cause this problem.
Thanks.
i7 920
GA-EX58-UD5
Nvidia GTX 260
Thanks.
