Bios setup help please
20 Jan 2004
I've just built a new PC but need help optimising my bios for my new PC.
Can anyone help me out here? I eventually wanna so some minor overclocking.
I have the following setup...
Thanks in advance to those that help me out!
Hi, well first off we need your spec so sort your sig, or post it.
How familiar are you with the bios ? What external equipment do you have connected to the pc ?
OK, I have nothing external plugged in at all.
I was familiar with the bios a few years ago but not now!
Thanks in advance for any help you can give me!
This is my setup...
Windows XP Pro
Enermax Noisetaker 600W EG701AX-VE(W) SFMA ATX2.0 SLI Compliant PSU (CA-021-EN)
ASUS P5W DH Deluxe motherboard
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) CPU
Arctic Cooling Freezer 7 Pro CPU Cooler
Papst 4412 F/2 GL 120mm Fan - 3 Pin (FG-008-PA)
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
Galaxy NVIDIA Geforce 7800 GTX 256MB PCI-Express
1 x Western Digital Raptor 74GB WD740GD 10,000RPM SATA 8MB Cache
Zalman ZM-2HC2 Heatpipe HDD Cooler
2 x Hitachi Deskstar 7K500 SATA 500GB 7200RPM 16MB Cache
Leadtek Winfast DTV2000H Hybrid Digital & Analogue TV Tuner Card
LG GSA4163B True 16x Super Multi DVD Rewriter DVD writer
Mitsumi floppy disk drive
Logitech G5 Laser Mouse
Mouse Bungee
Steelpad S&S Mouse Pad
Logitech UltraX™ Media Desktop keyboard
hp L1925 19" TFT
ASUS Vento red ATX case
Sony EyeToy webcam
Creative Inspire 5300 5.1 Speakers
I was looking for something more upto date but couldn't see anything. Problem for me is i'm an AMD user so am not up to speed on tweaking Intel.
Is there a specific area you have questions about ?
If you wantto overclock you should post a thread in the overclocking section, they will know how to set it up for maximum effect.
Yeah, basically I wanna overclock but I'm not sure which settings I should enable or disable without my mobo going into a fit.
I noticed I had to Disable Hyperpath 3 in the Chipset section of the bios for me to push the FSB...
You lost me at Disable Hyperpath 3. Not a clue mate. :confused:
Post a thread in the overclocking section. You will get more and better help there. Everyone seems to be going C2D and clocking them. :)
I need to know the best settings for these things in my bios...
prg buffer length
link latency
peg root control
peg link mode
slot power
virtualization technology
execute disable function
cpu internal thermal control
dram ecc mode
dram throttling threshold
pci express freqency
pci clock sychronization mode
I don't know to what extent this will help, but here is the section of how to set up bios on another ASUS board documented on a Corsair System build report.
CLICKY
