Looks good!
Now order it, and don't forget a build log when the parts arrive![]()
Going down today as i'm local so expect a build log today!
Looks good!
Wouldn't the OCZ be able to power two 6870's then if i wanted them at a later date?
If you can afford it, it's one of the best monitor available right now.I must admit I'm not very clued up on monitors, but how come you've gone for the dell? It's only 23", and you can get 24 inch monitors for less than £200.
its got the power, it just only has two PCI-E connectors, so you would have to use molex to pci-e power adaptors, which look ugly
the XFX has four connectors as standard, but luckily if you aint worried about this the graphic cards will come with molex to pci-e adaptors anyway, so no extra purchases are needed.
If you ever need to resort to molex adaptors, you can just use 6/8-pin extensions and bury the adaptors out of sight somewhere. But then for the price of the extensions, you may as well have just bought a suitable PSU in the first place![]()
There are 3 monitor panel technologies, from cheapest to most expensive; TN, VA and IPS.
TN panels are what in 99% of cheap to sub £200 monitors, they're fast so are good for gaming but otherwise that's about it. VA panels have decent colour and black levels but are the slowest of the 3. IPS panels are the cream of the crop, best colours, contrast, viewing angles and also fast, particularly that Dell.
It may be 23", but it's still 1920x1080 and it is ridiculously good, despite the price, it's one of the most affordable IPS panels out now.
The only drawback that I've read on the Dell is that some people have a green-pink tint across the screen, some worse than others. So it could turn into a case of monitor tennis, where you have to send it back until you get a decent one.
That was the panel types in a nutshell, there's still different sub panel types like M-VA, P-VA, E-IPS, H-IPS but what I said above still holds trueAh, cheers man, I always wondered why some monitors were so much more expensive. I knew there were different panel types, but never knew which ones did what.
Purchased, done, build thread probably later today.
