ok, here goes, I have a conroe 6400 cpu (1066 fsb )
and a 6800 etreme (512) that is "i think without looking a the box" 1024 clock
so do i need to get ddr2 8500 to stop the memory slowing down the system? or would 6400s be just as good.
or would the difference even be noticable?
I am currently using an asrock dual-vsta with ddr1 in it, so I will be looking to replace the motherboard as well (I beleive the Asrock will take ddr2 6400 but not 8500 which is why I am asking - getting 6400s woudl mean holding off on having to shell out for a new MB for a short while)
thanks
thanks
